Текущее время: 16 фев 2026, 19:43
 Заголовок сообщения: Продам новую гарнитуру
СообщениеДобавлено: 14 окт 2014, 23:48
Продам новую гарнитуру PNR AH-2000
100$
0673223034
AH-2000 PNR headset
Overview
PNR Aviation Headset
GA Use Dual plugs
Molded cord assembly made to exceptional pull and flex standards
Noise-canceling microphone
Strong steel Boom provides flexibility and steady microphone placement
Straight cord from headset to molded plug, 150CM
Color: Black,
Noise Reduction Ratings (NRR):24dB
Specifications
Headphone
Type: Dynamic (F40)
Frequency Response:100Hz to 8 kHz
Sensitivity:95+/-5 dB SPL
(1 kHz, 1 mW input per earcup side)
full volume on ear simulator
Impedance:150 ohms (300 ohms each; wired in parallel)
Rate Input:100mW
Max. Input: 250mW
Microphone and Amplifier:
Element Type: Noise-canceling
Frequency Response:100Hz to 5 kHz
Operating Voltage (supplied by aircraft ):8-32 Volts DC
Matching Impedance: 150-1000 ohms
Sensitivity:-33+/-4 dB
(ref: 0dB SPL=20.0uPa at 1 kHz with 10 Vdc 150 ohms AC load)
General
Operating Temperature: -20 to 70°C
Cordage: Straight cord from headset to molded plug, 150CM
Intercom Connections Plug:
Earphone Plug: PJ-055( .25"F6.3 phone plug)
Microphone Plug:PJ-068( .206"F5.2 phone plug)
Golden plated connectors
Headset size range Height: 10 to 14 cm
Color: Black
Boom: flexible boom
