Текущее время: 15 фев 2026, 21:11
 Заголовок сообщения: Турбопроп в 100 л.с. с документацией на ebay.com
СообщениеДобавлено: 31 дек 2018, 22:15
Кстати а если поговорить об экспериментальном Турбопропе в 100 л.с. который показан на картинке - то я бы поискал заинтересованных лиц среди наших постоянных интернетопочитателей. Посмотрите данные из ебейки - Я здесь все перепостю на случай если куда нибудь денется это об@явление
This is the only prototype made. It is a DARPA Military project made by SWB. It is a turbo shaft that weighs in under 40lbs and produces 101HP. Yes that is right! 40lbs self contained free turbine turbo shaft at 100HP. Test data shows 460 Lbs of static trust off a 3 bladed warpdrive prop. Perfect for a VTOL device helicopter or ultralight. This is not a RC type engine with limited life. It has its own self contained oil system that lubricates all systems including the gearbox and the engine. The main engine has its own oil system, and it does not require mixing oil with the fuel. This engine does not require deloading the engine during start up since it is a free turbine and has N1 and N2. You also do not need a special prop to run this engine. A warp drive or Ivo will do just fine. All rights, molds, tooling and programming where sold from SWB to a ultralight company in Florida 70,000USD then to me. Engine comes with test stand as well, but engine will be taken off prior to shipping. This project cost the Military 1.2 Million dollars. I have thousands of pages of documents on every aspect of the project that I will include. I have all the drawings, some of the CNC code and pictures of every step of the project. I also have several videos of the engine running. This engine comes with everything pictured except the alternator and the prop no molds or tooling are included. I have not ran the engine with the controller provided, but tested it with a voltage controller on a fuel pump instead. Contact 661 428-1850 with shipping questions . It is the buyers responsibility on arranging shipping. . US sales only
Код:
Это военная разработка и единственный прототип в готовом виде. Это турбовинтовой движок весом всего в 18 кг который выдает на валу 101 лошадку. Представьте себе  40 фунтиков (~ 18 кг) веса с винтом на валу и целых 100 лошадинных сил. Проверочные данные показывают тягу в 450 фунтов статической нагрузки снятой с 3 лопастного пропеллера Именно то что надо для ВиТола, Домашнего Вертолетика или Ультралайта. Это не модельный вариант с ограниченной эксплуатацией. У двигателя полностью независимая система смазки покрывающаяа все системы включая стартер и движок. Сам двигатель имеет свою систему смазки и не требует смеси топлива и масла. Двигатель не требует перезагрузки во время старта ввиду того что это самозапускающаяся турбина у которой есть N1 и N2 . Не нужен и специальный пропеллер для этого случая . Пропеллеры от "Warp Drive" или "Ivo" вполне подойдут. Все права на этот движок , матрицы, документация ,  оснастка и программное обеспечение были проданы за 70 000 в Ультралайтную компанию во Флориде за 70 000 у.е. а потом попали ко мне . Двигатель продается на стенде. Но будет снят перед отгрузкой. У меня более тыщи страниц документации на каждый элемент разработки - все будет включено. У меня есть все чертежи , некоторые файлу для ЧПУ и картинки на каждый шаг процессса изготовления. У меня есть и несколько видео этой игрушки Продается все за исключением пропеллера и генератора , у меня нет матриц  и нет готовой оснастки - только документация . Я не запускал движок с контроллером , но протестировал все на нагрузках .
